1 - 10 of 10 Posts
Like a dummy was filling my ATV. Got done grabbed wrong cap . Plastic insert fell into tank.
It's small and thin quarter size ( insert from 5 gallon red plastic jug)Will this cause any problems if left in tank.? Definitely won't dissolve made to be used with gas.Thanks for a quick reply.
I'd get it out, just because it'd aggravate me knowing its in there.
However I'm note sure what bike you have; but I don't see how it would cause a problem in my tank, maybe the fuel gauge at most.
I wouldn't worry a bit about it , it won't plug your intake . Keep looking for it whenever you have the cap off , it'll show up someday .
Well I'm guessing it floats, so maybe fill it way up and see if you can reach it with something? If not, I wouldn't worry about it
Plastic doesn't float in gasoline and the contour of the tank makes "grabbers" n other such mechanical devices virtually no good. Also the fuel sending unit with pump n screen could incur damage as a result using such retrieval devices. Unfortunately the safest way to remove that cap is to remove the tank essentially turn it over and shake it out.
I wouldn't worry about it... Seems like you are more likely to cause damage getting it out, than you are to have it hurt anything.
Sean
The screen on the fuel intake will keep it from blocking anything up. So I wouldn't worry about. Some day you'll have reason to pull the fuel pump / sending unit. You can get it out then.
I did something like this last year...I took the tank off and shook it out. The sending unit is in there so don't go poking around. It was a fairly easy job, took less than 1-1/2 hours, I had a repair book to help guide me. And now I know how to replace the sending unit if I need to, that cost me plenty when it crapped out a few years back!
1 - 10 of 10 Posts
