Was in a bog the other weekend and could smell rubber and had no wheel spin (high range) so I thought I've toasted the belt and bought a new one, anyway when I pulled the cover off the belt looks ok except for the longitudinal grooves in the belt? All the help videos I have looked at had none of these grooves, they also said in neutral that both clutches are spinning and this stops hot spots and wear on the belt however when in neutral mine is spinning the secondary clutch but the main one will not engage until 1500rpm thus making grooves in the belt. (First pic) Do I need to make an adjustment somewhere or what? Any advice appreciated.
Second pic is the bike in neutral idling, you can see that only one clutch spinning.
