13 sportsman 500HO. i was gonna get a set of zilla 26-9-12s for the fronts. Will i need to flip the tie rod around to make this work?
2007 500x2 le
You'd be close I have a 10.in wide up front and that was to wide 9 should fit I'm sure someone will know ! Also try the search button lots of good threds on tire sizes and wheel offsets
1/4" spacers seem to be the trick for 26x9-xx front tires on the Value Lines with oem wheels/offsets.
