I have a 06 sportsman 800 that I did a TPS adjustment on and the voltages I used for my settings were found on another forum and the quad isnt quite right yet so I figured Id see if anyone could check their manual to see what the TPS voltages should be for the 06 800? As of now I did the base voltage with idle screw out to get .528 and then turned in the idle screw until I hit .640 like I saw was the spec for that machine. Once I started it the idle was way to low so I bumped it up to .710 which is the spec for the 05 and the idle is now at 1050 to 1100 when warm, but it has a weird hick up that causes it to die while warming up. If anyone has the correct voltage specs from the manual hopefully it will help me get this thing dialed in.
