1 - 20 of 22 Posts
Both my wifes and my neighbors 2014 570 sportsman start very slow. Its almost like the starter is weak, or the battery is weak....its odd that they both do this.
Mine starts up every single time on the second or third crank. Definitely not slow to start! My motorcycle doesn't even start that fast.
Mine starts fine and quick but I know what you are asking about. It sounds like the battery is weak even when fully charged.
Mine does the same thing.
Mine does it also
I would describe it as turning over slow. Sounds like a low battery but I think this engine has a long stroke making it sound like that.
I find my 500 turns over hard also but these are high compression engines. Even with a new battery, mine still turns over slow.....
Discussion Starter · #8 ·
Im finding that this is very slow, and almost taking 3 seconds or so to start up while cranking over.....neighbors is doing the same thing. Im going to take a video of it at some point and post it on here.
With my 570 if I just crank the key it takes longer to start then if I wait a second or two for the fuel injection to prime itself.
Nothing like a weak or low battery though
Discussion Starter · #10 ·
Ok the new thing is now it is no longer firing up within a second or two....its taking several turn overs of the engine before it starts up. I have owned 10+ ATVs/UTVs and never noticed one to do this. I dont know how to explain this to the dealer. Overal Im not to happy with the build quality of this thing.
Several heat shield noise NVH issues that I had to resolve...seat interface to where tank plastic is fits terrible, engine turns over very slow, lots of clunking in drivetrain....not to impressed and I have like 20 miles on it so far.
Dang dude, that's odd. I'd feel ripped off too. My 570 starts every time, doesn't make weird noises, and I have like 8 hours and tons if miles on it. Hopefully they fix your ride.
If i can remember I will take a video today after work. I know if i turn mine over and it doesn't start fully, it has to turn over quite a bit to start then. Like too much fuel gets in and floods it.
Discussion Starter · #13 ·
That is similar to both of ours. When I get back home I will take a video also.
johnson
I also bought a 14 570 and mine seems to take longer to start, also lots of drive train noises, I'm thinking about buying a more aggressive clutch kit, I also noticed the other day after it sat for a week that it would barely move itself forward or back as tho the clutch was slipping or not turning at all, I've been very frustrated with this machine, next time I'll spend the money and buy a suzuki or yamaha
Hey everyone. Looks like an old and ongoing issue. I think I found the solution. My 2016 Ranger, eps had a slow start since day one. And sometimes, it would just click, click, click....upon repeated efforts, it finally started. Then the power steering light would come on.... time and time again.
Well I went to replace the battery and they directed me to the typical 220 ATV/UTV cranking amp battery. But it wasn't the answer. Upon research, we need to install a 450 cranking amp battery...... Well mister!, that fixed it! Turns over and starts up like a frightened rabbit 🐇 now!
Food for thought.
Food for thought.
to the forum
Reactions: Triumph knight
All the little nuances went by the way side when I installed a new AGM battery!!! Never again did that compression stroke double tap need apply 😉.
Plant Motor vehicle Road surface Tree Asphalt
1 - 20 of 22 Posts
