1 - 14 of 14 Posts
Welcome to the board!
First check the air filter and make sure it is clean. Inspect spark plug and fuel filter and all carb and tank vent lines. Then if they are not the problem you will probably find that the carb needs to be cleaned. Make sure when cleaning the carb you remove the pilot jet, main jet and the needle valve and clean the entire carb.
Discussion Starter · #8 ·
hey dirty dawg where bouts in minn im orginally from there i was born there and used to live in baudette years ago
Have spent most of my life living around the twin cities area. I have to live out far enough where I can jump on the ATV, Snowmobile or RZR and go for a rip.
1 - 14 of 14 Posts
