1 - 10 of 10 Posts
What is everones take on oem vs aftermarket drive belts
i'm into my clucch now doing a clutch kit and was just thinking about install new belt while in there, it looks good no burn marks
i know yamaha quads dont work well with aftermarket belts
any recomendations for aftermarket ?
I tried a gates extreem. I didn't really like it as well as the stock. Went back to stock. They last just as long or longer.
The only belts I have gone through is when the one way bearing seizes to the shaft and grinds away the inside of the belt.
D
I have the epi extreme. So far so good. The one way bearing was going bad so just put on a 2 way. That should help the belt last even longer now.
Sent from my SM-G955U using Tapatalk
What brand of 2 way bearing did you get ?
FYI I been using a Gates C12 on my 1000XP and it's doing good.
Two Way Bearing .... https://www.ebay.com/itm/3514609-PRIMARY-DRIVE-CLUTCH-NEEDLE-BEARING-FOR-Polaris-SCRAMBLER-850-2015-2019/283389791182
This also fits the 1000. I put it in my 1000 and my 850
D
Just the Polaris bearing off the scrambler.
I too am shopping for a new belt. Always heard use stock belts but man are they expensive. Had a buddy request the Gates carbon fiber. Not sure what I’m buying yet.
OEM works every time!!!!! If you can get a gates to work then that'll work too.
i agree, i never had a problem with a OEM belt but tried the Gates carbon c12 belt because its much cheaper and suppose to not stretch !
i only have first belt break in ride on it so cant really tell .
1 - 10 of 10 Posts
