2019 850HL, 2024miles and 221hrs. Applied 1/2-3/4 throttle while moving and get a popping noise, not every time. Same noise is occasionally hear when decelerating at low speed using only the engine and no brakes.
I can’t tell for sure if it’s coming from back end or from the transmission. I did kind of feel it in my boot, but was going down into a dry creek bed when it happened and may have pressed it tighter to the frame at the same time.
I did look at the rear shaft into the rear diff and it seems a decent bit of movement before engaging the driveshaft when I roll it, at least to me. Not sure how much backlash is considered normal. I am the second owner, so not sure what it was when new.
Not a ton of info I know, but all I have right now as I’m in the woods with no lift. It still runs and drives fine as long I roll into the throttle, and watch how I decelerate.
