Hey so today while greasing the nipples on my 2005 sportsman 500 i was greasing the nipple on the yoke and realized that there was a bit of play in my driveshaft i was able to move it side to side and up and down a minimal amount is the shaft meant be tight or have a bit of play ?
Thanks Jake
Mine is tight. ..
It could either be the splines on the shaft going into the tranny or you need new u joints. Hopefully it will just be u joints because if it is the splines on the tranny it all has to come out to be changed. A friend of mine just did the splines and he said it is a PITA. It should be snug without much movement at all.
Ronnie
