2005 Sportsman 800 EFI
Have ongoing issues I cannot resolve. Replaced broken fuel pump and machine was running great. After two weeks of good use, while idling in my driveway it killed and wouldn't restart. Now will start and run for a few seconds but kills as soon as I touch the throttle.
Done so far:
  • Replaced fuel pump
  • Replaced fuel filter
  • Changed plugs
  • Oil and filter change
  • Replaced TBAP wiring harness
  • Used fuel pressure tester and cannot get good pressure off fuel rail
  • No Codes
  • Confirmed good spark
  • Confirmed good battery voltage
Starts with starter fluid
Confirmed good fuel into and out of fuel filter, can see strong pressure when cycling on the pump with the key.
Further down the line, very little pressure but definitely decent amount of fuel out of the test, schrader valve.
Appreciate any ideas or what to try next....
So you have replaced the fuel pump twice? if not, install a new fuel pump or repair connections
I have not, only one time but the flow to and after the fuel filter is very strong. The issue seems further up the line, before or related to the fuel rail? Can't get a good pressure reading from the schrader valve.
Flow and pressure are two different things - like volts and amps
You can have a battery with voltage, but as soon as current starts to flow the voltage drops - as an example, take two garden hoses of equal length, but of different diameters (one 1/4 inch and the other 1 inch) - connected to the same water source with say 30 PSI of pressure, with a 1/2 spray nozzle attached to each hose, which hose will flow more water and which hose will have the best pressure?
You may have flow, but fuel injection works off pressure - find the leak or blockage between the pump and the fuel rail and if none, install a new pump
Flow volume = amps
Pressure = volts
When you kink the line = resistance
It's that simple!
Reactions: SAR Sportsman
