Thanks to advice from this forum, I changed the electric starter out on my recently acquired 06 450 Sportsman. It put up a bit of a fight but I got it out with some judicious use of newly made up obscenities and twisting and pulling. I put a bolt in the lower position with a shorter head height which made installing the new one quite a bit easier. Now onto the wheel bearings. Will freezing the bearings be enough to allow the new ones to slip into place or will some force still be necessary? I made a bearing press for dirtbikes using heavy threaded rod, flat washers and repurposing of my impact sockets. I figured something similar would probably work for the ATV as well.
I put the bearings in the freezer, and heat the housing with a torch. Still requires some persuasion though.
I just replaced all the bearings on 2 sportsman's, I had them in the freezer and sprayed them with wd40 and they all went in easy breezy, but I used a 12 ton press which I bought from HF for only 112.00.
Make sure to add water resistant grease to the bearings. They dont have enough from the manufacturer to make it very far.
Sent from West 'By-God' Virginia!
