Battery is new, and starter is new. All I get when the starter button is pressed is a click from the relay. I do not know if the relay is bad nor do I know how to check this out. I was told to check the solenoid. I traced the battery leads out and they do not go to a solenoid. If there is one on the machine I do not know where it is at. If you have any suggestions I would certainly appreciate them.
i believe on those the starter relay is the solenoid.did you clean all the connections at the relay? try to bypass it??
And welcome to the board!
