1 - 1 of 1 Posts
2013 Polaris Sportsman 500ho
electric problem
instrument cluster if I put in high speed flashes continuous and after few minutes loss of speed put shifter in low instrument cluster stops flashing and runs okay. Also when shut machine off instrument s stays on even if ignition switch removed have to disconnect battery then reconect it will stay off tried new ignition switch engine cranks but won’t fire so put old switch back in. Any suggestions checked for a wire grounding did not find one
1 - 1 of 1 Posts
