1 - 2 of 2 Posts
I bought this 08 Polaris Outlaw 525 about a week ago and on the second day of riding it, the headlights wouldn't turn on and would come on every once and a while and the tail light would flicker. Then the starter button wouldn't work and so I had to roll start the quad for a day. I took all the connections off and cleaned them out and lithium greased them all. Still wouldn't start on it's own power, I roll started it and it ran perfectly fine for 30 seconds and died. Upon further inspection, the wires to the tether had been cut by the previous owner. I replaced the handlebar start/light switch and now it will roll start but still no battery start. And the battery is fully charged. Not quite sure what to do here.
It the ignition switch,, to test flick it on and off..on and off over and over when in neutral! if the green neutral light flickers and works randomly then you found your problem, the main plug is also a problem and needs to be cleaned but sound like its the key switch
1 - 2 of 2 Posts
