My father in law just gave my son his 95 sportsman 400 and I am trying to fix the few minor problems with it. I put a new battery in it and it still would not start with the start button. It will try but acts like a weak battery but I am sure it is not. It will pull start just fine. Also when I try to put it into reverse it dies unless I engage the overdrive button and keep it depressed. Any information would be greatly appreciated. Thanks.
First welcome to the board!
Sounds like the starter, and as for the back up issue, may be a wiring issue. could also be a wiring issue for both of them. get the repar manual and check the harness with a meter if you can.
As you can see, Polaris just spliced wires everywhere on this machine. Low beams are tied to alot of things, including the fan switch and motor. Sounds like a shorted wire to me which I believe to also have on an '05 I just bought. Different problem but still a strong enough short to kill the engine.
