I have a 04 sportsman 500, that cuts ignition when I turn it sharp to the left. The problem does not happen constantly so it has become difficult to trace. I notice it happens the most when it gets wet. Any ideas? Also does anyone have a wiring diagram for the 04
Is the key by itself, or is there an attached key chain?
Sean
If not a key chain hitting the gas cap, Its probably the wiring around steering stem, they get it too tight fron factory, have to take frront plastic off and remove wiring from harness to find bad spot.
x3 on the keychain. x2 on the tightness at the steering stem. Check battery connections too.
