1 - 2 of 2 Posts
I recently purchased a 1988 trailboss 250 it starts and runs fine but it's not charging battery any ideas on possible problem? I'm assuming since it runs that stator must be working. I connected up volt meter to battery connections all I get for voltage is 12+ volts and voltage drops off once headlight is turned on with engine running at abot 2000 rpm. Is getting starter out a real headache as well? Any help would be great Thanks
Welcome to the board!:med:
1 - 2 of 2 Posts
