I had a failure on my machine which took out the piston. Just rebuilt and eliminated the oil injection. I'm mixing 50:1. I have read I should replace the throttle cable and possibly put in an oil block plate. Is this totally needed? I don't think the block is but possibly the throttle cable can hang up so I should change this?
Also, should I change the setting on the needle valve for the carb?
Thanks!
Thanks!
