1 - 2 of 2 Posts
did anyone have this code come up before? atv runs fine. when i go to start it all i get is the starter click noise for a couple tries then it fires up. Service engine light comes on and displays displays this Idle Air Control error code 520 193.
i noticed 2 things......one my throttle seemed a little loose. i tightened it about 3 turns to get into specs.......second i put my battery on a meter and it is roughly at 60% and will not hold a higher charge. . . i am going to replace the battery as well. cant hurt.
But has anyone experienced this code and what did you do to reolve the issue?
thank you in advance!
1 - 2 of 2 Posts
