1 - 2 of 2 Posts
Hey guys seeing how thiese quad have rubber mount how much play is too much. If I grab the engine shiuld I be able to move it. I just replaced the lower mount. I will try to up load a vid in a bit.
use a pry bar and give it a good bit of force(12-16" bar). You can soon tell. There should be a little play but not much at all because the rubber is just for torque and vibration,maybe up to3/16" at a guess.
1 - 2 of 2 Posts
