Do you mean the 2 hoses that come out the near the bottom front of the engine leading to the oil tank? If so, no - one is "in" the other "out" - they must remain as is. I wouldn't disconnect them - no real reason unless they're rotted/cracked & need replacement.
In changing your engine oil, don't bother with the metal screen (no one ever finds it dirty) at the bottom left of the oil tank or the crazy priming process. If you have a separate crankcase oil drain bolt, do drain it. Some on here don't and think its ok - its like changing the oil but not the oil filter. :banana:
