1 - 2 of 2 Posts
not too hard of a job. just take spark plug out ,take valve cover off,set the piston at top dead center(look at timing mark to verify it is at tdc, the camshaft also is marked with 2 dots ,just make sure they are parrallel with the valve cover),set intake and exhaust at .006",there are 2 int.and 2 exh.
1 - 2 of 2 Posts
