I have a 2019 450ho, utility sportsman. Is there a different engine temperature sensor ( lower temp) for when the radiator fan will turn on. I really don't like the 200 deg temp engagement. Huge temp swing, I would prefer a fan engagement, more around 185. Or has someone wired in a fan switch without hacking the harness!
You can also have RVSPerformance retune the ECM for lower fan temp set points.
Thanks for the tip on the tuning. Pretty pricey for just a temperature setting change. $300. I'll wire in another fan for that price.
