1 - 16 of 16 Posts
While working on this stalling issue, I noticed at idle my engine has a slow wobble, you can watch it move 1/4” or so, slowly. Rev it and it turns to a vibration, not severe though. This normal?
Motor mounts are bad.
No, it shouldn't be doing much rocking or vibrating when at idle..... I'd check the motor mounts. Is it running fine otherwise??
What Year / Model machine? Help us, help you!
It’s a 2004 Sportsman 700 efi. Other than the stalling issue it seems to run fine. It’s almost like a bent clutch and the belt is pulling on the engine but I don’t think that’s it. And at idle, it’s not like it’s shaking, more like swaying? Everything seems solid when I pull the engine around by hand. I haven’t had the belt cover off to look there yet.
Your machine has four mounts so you may not necessarily be able to rock the engine by hand and tell they're bad. The machine is nearly 20yrs old I would say there is a high probability those mounts have seen better days.
On the twins like yours, its usually the front mount that the rubber part of the mount detaches from the metal base of the mount. Common issue.
You have to use a pry bar right beside the mount to lift the engine while looking closely to see it.
I’ll check tonight while I’m finishing up the wiring modifications. Thanks guys.
All the mounts seem to be intact. I'll get back once I get the belt cover off.
Those engines aren't super smooth and do vibrate a some. Unless its excessive it may just be normal. One thing that will cause an increase in the vibration is a belt with a burnt spot in it. It'll get even more noticeable on acceleration under load if that's the issue.
Discussion Starter #11
Turns out, the belt is smoked. Previous owner installed a Polaris belt +/-500 miles ago, but the wrong belt. Ordered a Gates Gforce belt to replace it.
Thanks for the update. This helps us all learn potential failure modes. Glad it was a simple fix.
At idle the clutch is not in contact with the belt, the primary should be disengaged. Are you sure the is problem solved?
Discussion Starter #15
Positive. Not in gear the light tension spins the secondary, the belt had thin spots, essentially making the belt longer and shorter while moving through the clutches. It’s all better now
Discussion Starter #16
I’ll put up some pics next time I’m logged in not through Tapatalk
1 - 16 of 16 Posts
