1 - 2 of 2 Posts
I have a 2015 polaris sportsman xp 1000, the problem is the engine starts right up, idles and then stalls after 2 -3 seconds, i tried to rev but just dies when you use the throttle , i have check engine light on, and the eps one (steering wheel light), got code 84-2, 84-19 and 190-2, i changed the speed sensor, check fuel pump, compression, timing, throttle cable, etc. everything is checked, the thing just wont idle, we check the ecm, but is weird that ecm gets very hot, it may be a overcharge some where or an electric thing?, may my ecm be bad? Im over 3 months having this problem, also we have check all sensors, all of the components, can anybody help me with this i will appreciate it so much THANK YOU!
Welcome to the forum
Reactions: Richardpeña
1 - 2 of 2 Posts
