So, getting closer to purchasing and wondering how durable the eps is on the 850 xp? What happens if the unit goes out while on the trail? Can you still turn the bars? Can you bypass the EPS or are you stuck on the trails? Thanks
have not seen many problems with the eps on any of the forums,one or two at most. if the unit fails you can still ride,it will be like riding a unit without eps till you get it fixed. no bypass to do.
