My 2000 scrambler 500 ho has a real traction problem. While operating in 2wd, it seems that the right rear wheel spins way too easily. If I loose momentum on a slight grade, the right rear wheel starts spinning and begins to dig a hole real quickly. I am still working through some problems with awd and would like to at least do some riding in 2 wheel drive but the excessive wheel spin makes this difficult.
I am unsure just how the rear axle works on the scrambler and am wondering if something is broken or needs to be adjusted there.
Am curious if anyone else has experienced similar symptoms? Causes? Fixes?
TIA
X2 on the hub.
