just a little manifold that goes between the case and the exhaust pipe. i hope this fiche helps
1 7542324 NUT(10) 2 Usage
2 7555716 WASHER(10) 3 Usage
3 5010192 BUSHING-RES. MT. 2 Usage
4 5410241 DAMPENER 2 Usage
5 5220901-067 BRKT,RH SUPPORT RACK Substituted by 5243469-067 1 Usage
6 5220902-067 SUPPORT,R.FENDER 1 Usage
7 3110030 MOUNT, MOTOR 1 Usage
8 7542432 NUT, JAM(10) 1 Usage
9 5410436 WASHER,RUBBER 2 Usage
10 7515316 BOLT(10) 1 Usage
11 7512666 BOLT(10) 1 Usage
12 7052083 PLUG, CLEANOUT 1 Usage
13 7512282 BOLT, BLACK(10) 3 Usage
14 7515140 SCREW(10) 1 Usage
15 7542141 NUT, RETAINER(10) 3 Usage
16 1260620 HEATSHIELD ASM. (Incl. Foam) 1 Usage
17 7555776 WASHER(10) Substituted by 7558301 1 Usage
18 7670060 NUT, SPEED(10) 1 Usage
19 7621462 RIVET(50) 1 Usage
20 5240179-067 BRKT,BLK,HEATSHIELD 1 Usage
21 7042031 SPRING, EXHAUST(10) 2 Usage
22 1260549-029 HEADPIPE WELD. 1 Usage
23 7042029 SPRING-EXHAUST(10) 4 Usage
24 1260588-029 EXHAUST WELD,BLK,(350) 1 Usage
25 3080530 WASHER LOCK ,(10) 2 Usage
26 3080285 NUT(10) 2 Usage
27 1260543-029 MANIFOLD, BLK. 1
yes, there is supposed to be an exhaust gasket between the head outlet and exhaust pipe.
