Hello there I recently picked up a 02 400 4x4 during a short ride the hot light came on I noticed the fan was not running I was wondering if there is a fuse box on this machine and where it is located thankyou
Hey another Canadian! Welcome to the board!
Theres no fuse or anything for the fan that you can check. THe best bet is probly the fan itself is bad, to check that just unplug the wires going to the motor and hook up direct to a battery and it should run. If it dosnt run then the fan motor itself is bad. If it runs then you have problems elsewhere. Hope that helps.
