Hello, first time posting on this forum. I have a 2006 sportsman 500 HO (carbureted). The cooling fan starts running as soon as the ignition is turned on, even though the engine is dead cold. I have tested the ohms on the coolant sensor and as per the service manual, it was out of spec so i replaced it (located in the left side of the cylinder head) still having the same issue! It seems like there is an electrical problem here, the service manual is not much help and after searching on this forum for a similar problem on a similar bike, all i can find is clogged raditor issues. So any help here is much appreciated! Is there a fuse or relay that controls fan function? and if so where is it located? thanks in advance,
-Mark, Va Beach, VA
-Mark, Va Beach, VA
