I have a 2017 Polaris Sportsman XP1000 Highlifter. My fans have stopped working,any idea what the issue would be?? Where could i start first and least expensive and if that doesnt work what next,etc,etc,etc
I'll try and get you some pics to go by. It's a sensor on the head. If it isn't working properly it'll prevent the fan from running. How did the fuses look. We're you able to locate and swap the relay with one of the others??? If the fuses are good try sealing the fan relay with one of the other relays and if the fan bumps then you know the relay is bad.
I cant thank you enough. I just walked in from work so I will do exactly what you have said too do. The illustrations are awesome,thank you for taking the time too help me!!!! I will keep you posted as too how it goes!!!!
SWEET!!!!!!!!!!! Glad you got it lined out!!!!!!!!
Related Threads
876.5K posts
113.2K members
Since 2008
