1 - 2 of 2 Posts
Hey guys, I have an 08 sportsman 800 ho in the nuclear sunset color. I want to upgrade to maxxis bighorn tires (not 2.0) and I have a few questions
1. I will be using stock rims, are 30 mm spacers enough?
2. Don't want to have to do clutch work. Can I use 27x9x12 / 27x12x12 safely or should I stick with 26x9x12 / 26x12x12?
3. If I can use the 27s, will they rub/how close will they come? Like is stock height ok or should I purchase a 2" lift as well? Thanks for the help :D
No need for a lift. 27" tires will be fine with your stock clutch. It depends on which specific tire you decide to get as far as spacers are concerned. Some 9" will clear and some will not because they are not all exactly 9" wide. The 30mm spacer should cover you if they don't clear
1 - 2 of 2 Posts
