1 - 15 of 15 Posts
Good lookin ride!!
Sent from my MB886 using Tapatalk 2
Discussion Starter · #6 ·
William, she's a stocker. Fronts are AT25x8-12 and the Rears are 25x11-12 I'm going to prob go a little larger down the road one I run these tires out but the got a lot of life left. As far as a lift there is none that I'm aware of. I bought it from a lady who's husband died. Seems pretty much stock. only 333 miles and 116 hours. Just used around the house and to plow.
Discussion Starter · #7 ·
I do eventually want to get slightly bigger tires prob. not a lift. so as big as I can go with out and then do a stealth snorkel set up. not looking to get crazy just kill deer and I have some slough areas where I'm at. can't wait!
Very nice find :) Enjoy
Tire & Wheel Specialists
Great looking bike. I put over 9,000 miles on my 03 700. Loved that machine. It always had a different sound. My wife said it sounded kind of like a jet engine. She could always tell it was me coming.
You can't go any wider on the front tires without spacers or offset wheels. They will rub the front struts.
Enjoy that awesome ride. Watch the carb boots. I replaced a couple of them. They tend to crack from the vibration. If you see them off you will wonder how that can happen as they are very thick. If it starts to backfire look here first.
Welcome to the forum!
If you go wider than stock you will either need spacers or offset wheels. Also the type of tire you want will make a difference as well. Some tires are wider than others.
The older machines are harder to go with larger tires than the newer ones. I always ran stock size and has a ball.
If you are wanting more of a mud tire you may want to take a look at the Interco Swamp Lite in 26x9-12 and 26x10-12. The 9 will more than likely rub with stock wheels.
Interco Swamp Lite tires listed by size
1 - 15 of 15 Posts
