13' 500 HO, manual says 25 hrs for the first oil change, but the dealer where I bought it says 10 hrs. When did you guys do your first oil change?
Just curious , how do you know oil pressure went up " dramatically " ?50 hours on the engine and everything else but the front gearbox. 25 hours if riding it hard and wet on the front gearbox. Mobil 1 0w40 in the engine with a napa gold filter. Sorry but Fram sucks and found that out when I switched to napa gold in my truck this year. Oiled pressure went up dramatically as the napa gold and Bosch filters have more filter area allowing better flow. Had always used high end Frams up until this discovery. Ready for a front gearbox change this weekend and will use Mobil 1 ATF.
I have an oil pressure gauge in my truck. 10-25 more PSI based on engine RPM.Just curious , how do you know oil pressure went up " dramatically " ?50 hours on the engine and everything else but the front gearbox. 25 hours if riding it hard and wet on the front gearbox. Mobil 1 0w40 in the engine with a napa gold filter. Sorry but Fram sucks and found that out when I switched to napa gold in my truck this year. Oiled pressure went up dramatically as the napa gold and Bosch filters have more filter area allowing better flow. Had always used high end Frams up until this discovery. Ready for a front gearbox change this weekend and will use Mobil 1 ATF.
