1 - 20 of 84 Posts
What's the top speed? What kind of gas mileage does it get?
Just wanted to be the first to ask. :)
The axels are crap. I broke five in one day. :chairfall:
You broke 5 axles on a scrambler xp1000 where did you ride it at
Hey what's up jc? Just joking around. u know that's going to be a problem, big motor and big hp, that right thumb is going to be the grim reaper of axels. And a lot of guys are going to come on the forum and complain.
Side note my bushings are holding up great. Question for u when reassembling the a-arms do u suggest any thread lock?
Yeah I figured it was a joke that's why I signed in on it and yeah as far as a thread lock I would use it. good to hear your bushings are still holding up good.
What I wanna know is why is it the razor has 108 horsepower and the atv only 89 I bet 2 years from now it will have 92 horsepower four years from now it will have 96 hp
Has anyone heard a price yet
I heard 13299, someone on here posted in in another thread
Yeah I just pulled up to player sad $13299.00 is the suggested retail price
ENGINE
Engine Type
4-Stroke SOHC Twin Cylinder
Displacement
952cc
Fuel System
Electronic Fuel Injected
Cooling
Liquid
DRIVETRAIN
Transmission/Final Drive
Automatic PVT P/R/N/L/H; Shaft
Drive System
On-Demand True AWD/2WD
SUSPENSION
Front Suspension
Dual A-Arm 9" (22.9 cm) Travel
Rear Suspension
Dual A-Arm, Rolled 10.25" (26 cm) Travel
BRAKES
Front/Rear Brakes
Single Lever 4-Wheel Hydraulic Disc with Hydraulic Rear Foot Brake
Parking Brake
Park in Transmission/Lockable Hand Lever
TIRES / WHEELS
Front Tires
26 x 8-14; 489 II
Rear Tires
26 x 10-14; 489 II
Wheels
Matte Black 8 spoke Cast Aluminum
DIMENSIONS / CAPACITIES
Wheelbase
53" (134.6cm)
Dry Weight
767 lb (338 kg)
Overall Vehicle Size (L x W x H)
82.3" x 48.6" x 48.4" (209 cm x 123 cm x 123 cm)
Ground Clearance
11.5" (29 cm)
Seat Height
35" (89 cm)
Fuel Capacity
5.25 lb gal (19.9 L)
Front/Rear Rack or Box Capacity
25 lb (11.3 kg)/50 lb (22.7 kg)
Payload Capacity
290 lbs (131 kg)
Hitch Towing Rating
1,500 (680.4 kg)
Unbraked Trailer Towing Capacity
1,914 lb (868.2 kg)
Hitch/Type
Standard/1.25" Receiver
FEATURES
Cargo System
Lock & Ride
Lighting
White LED; Hi/Low Beam; Single Rear Taillight
Electronic Power Steering
Standard
Instrumentation
Digital Gauge, Speedometer, Odometer, Tachometer, Two Tripmeters, Hour Meter, Clock, Service Time, Diagnostic Indicator, Gear Indicator, Fuel Gauge, Hi-Temp/Low-Batt Lights, DC Outlet
Scrambler XP® 1000 EPS
WHITE LIGHTNING
$13,299
US MSRP
STARTING AT
BUILD
Near GO
GET A QUOTE
Offers Insurance
it is not the same motor not even close, the new scrambler is a bored and stroked 850
Its actually only about 103 cc more then the 850 they should've just called it at 950
it is not the same motor not even close, the new scrambler is a bored and stroked 850 north and south motor single over head cam the razor east and west motor is twice the size will not fit in scrambler and double overhead cam 4 valves per cylinder
With that long stroke it will be a torque monster
Well lets just turn that motor north east south west and make it work.Lollol
I did not realize they were different motors
Inline with a gade on pricing.
Does it have a pull start? :) I heard a guy snapped 6 calipers too.
I bet they got 10,000 miles out of the bushings and wheel bearings
I would still take a gade 1000. It is a much nicer looking machine.
Bored a stroked 850? Jesus christ.... The 850 aas throwing rods out of the side of the block.
As much as big hp fans will think this is tits, i think its the wrong move by popo.
What r the biggest tires I can get under the 1k with out a lift?
probably 27's or smaller 28's
I thought I seen one on you tube with 30's with minimum rubbing on bumps
I'm lookin forward to Rick Cecco chiming in on this. Will be informative to get his take on it.
Wonder if his new machine will be the 1000 ? Polaris should give him one or somebody with deep pockets buy it for him.
1 - 20 of 84 Posts
