· Registered
Hi guys..I found a set of 28x10x12 front and 28x12x12 tires. Im running a stock 04 700 Sportsman. What do i need to make these fit on the stock rims?..or will they?. The fronts have the stock 25x8x12 now, so not sure if the 28x10x12 is too much for that rim.
I know a 2" lift needed anyway, clutch kit to turn them?..wheel spacers? or new rims?
The 28's are new and 500 for all 4...but if its gonna be another 800 to make them fit i wont bother.
Thanks everyone :)
· Registered
2017 Sportsman 850 SP, 2006 Predator 500
You might be able to make the stock wheels work, you'll for sure have to get wheel spacers for the front. As far as for a clutch kit, that will depend on just how aggressive the tires are, are they huge mud tires? If so then a clutch kit would be a good investment.
· Premium Member
Wheel spacers or offset rims to clear the tie-rod ends.
Reactions: 04700sportsman
· Registered
Discussion Starter · #4 ·
Thanks so much ?
So some 1" spacers will be enough for the front?
What about cranking up the rear springs for lift instead of the brackets that come with the kit?
Still wondering if the front 10" tires will be too wide for the stock rims.
· Premium Member
Stock rims and 1" spacers will clear the tie-rod ends.
You don't need a lift for 28" tires. Just crank up the pre-order.
· Registered
Discussion Starter · #6 ·
I like what im reading..found some 1" spacers for 158.00 Can. Thats both sides.
You guys are awesome :)
Just waiting on new front struts..i can push mine up by hand..lol
Reactions: bp405
