1 - 2 of 2 Posts
2006 500 sportsman ho carb new battery new regulator now the system is charging rite since I put it in the hot light is flashing but I noticed the previous owner wired it to come on as soon as ya turn the key so the fan is on all the time my question is , is there a thermostat in these bikes or is it just the tep sensor that screws into the side this is my first polarize bike had it for about 3 months now If there is a thermostat where do I find it and how do I check it lol any help would be awesome thanks
The thermostat is on the left side of the engine,as is the temp. sending unit. You may need to remove the plastic side cover for access to both.
The thermostat is located in a housing which is attached to the radiator hose, i doubt that ,that is your problem since the temp. light comes on immediately upon start-up.
Faulty temp.sensor or controller.
You really need to wire everything back to stock first.
1 - 2 of 2 Posts
