1 - 1 of 1 Posts
The question was asked but perhaps never answered - what size is the flywheel nut (part number 3083905) - for those who want to know, it is 16 x 1.5 mm RH thread with a 22 mm hex and appx. 6 mm in thickness - which means the threads on the crankshaft are also 16 x 1.5 mm also.
This nut is used on the following Polaris models:
1988 TRAIL BOSS 250 (X888528) - Crankshaft & Piston Assembly
1988 TRAIL BOSS 250 R/ES (W888528) - Crankshaft & Piston Assembly
1988 TRAIL BOSS 2X4 (W887527) - Crankshaft & Piston Assembly
1988 TRAIL BOSS 4X4 (W888127) - Crankshaft & Piston Assembly
1989 BIG BOSS (W899627) - Crankshaft & Piston Assembly
1989 BIG BOSS 4X6 (W898627) - Crankshaft & Piston Assembly
1989 BIG BOSS 4X6 (X898627) - Crankshaft & Piston Assembly
1989 TRAIL BOSS (W898527) - Crankshaft & Piston Assembly
1989 TRAIL BOSS 2X4 (W897527) - Crankshaft & Piston Assembly
1989 TRAIL BOSS 4X4 (W898127) - Crankshaft & Piston Assembly
1990 BIG BOSS 4X6 (W908627) - Crankshaft & Piston Assembly
1990 TRAIL BLAZER (W907221) - Crankshaft & Piston Assembly
1990 TRAIL BOSS 250 (W908527) - Crankshaft & Piston Assembly
1990 TRAIL BOSS 2X4 (W907527) - Crankshaft & Piston Assembly
1990 TRAIL BOSS 350L 2X4 (W907539) - Crankshaft & Piston Assembly
1990 TRAIL BOSS 350L 4X4 (W908139) - Crankshaft & Piston Assembly
1990 TRAIL BOSS 4X4 (W908127) - Crankshaft & Piston Assembly
1991 BIG BOSS 4X6 (W918627) - Crankshaft & Piston Assembly Big Boss 4X6
1991 BIG BOSS 6X6 (W918727) - Crankshaft/Piston Assembly 6X6
1991 TRAIL BLAZER (W917221) - Crankshaft & Piston Assembly Trail Blazer
1991 TRAIL BOSS 250 (W918527) - Crankshaft & Piston Trail Boss Update
1991 TRAIL BOSS 2X4 (W917527) - Crankshaft & Piston 250 2X4 Update
1991 TRAIL BOSS 350L 4X4 (W918139) - Crankshaft & Piston 350 4X4 Update
1991 TRAIL BOSS 4X4 (W918127) - Crankshaft & Piston 250 4X4 Update
1992 BIG BOSS 4X6 (W928627) - Crankshaft & Piston Assembly 250 4X6
1992 BIG BOSS 6X6 (W928727) - Crankshaft & Piston Assembly 250 6X6
1992 EURO BIG BOSS 6X6 (S928727) - Crankshaft & Piston Assembly 250 6X6 / W928727
1992 EURO TRAIL BOSS 4X4 (S928139) - Crankshaft & Piston 350 4X4/W928139
1992 TRAIL BLAZER (W927221) - Crankshaft & Piston Assembly Trail Blazer
1992 TRAIL BOSS 250 (W928527) - Crankshaft & Piston Trail Boss
1992 TRAIL BOSS 2X4 (W927527) - Crankshaft & Piston 250 2X4
1992 TRAIL BOSS 350L 2X4 (W927539) - Crankshaft & Piston 350 2X4
1992 TRAIL BOSS 350L 4X4 (W928139) - Crankshaft & Piston 350 4X4
1992 TRAIL BOSS 4X4 (W928127) - Crankshaft & Piston 250 4X4
1993 250 2X4 (W937527) - Crankshaft & Piston
1993 250 4X4 (W938127) - Crankshaft & Piston 4X4 250
1993 250 6X6 (W938727) - Crankshaft & Piston 6X6 250
1993 350L 2X4 (W937539) - Piston & Crankshaft 2X4 350L
1993 350L 4X4 (W938139) - Piston & Crankshaft 4X4 350L
1993 350L 6X6 (W938739) - Piston & Crankshaft 6X6 350L
1993 EURO 350L 4X4 (S938139) - Piston & Crankshaft 4X4 350L W938139
1993 EURO 350L 6X6 (S938739) - Piston & Crankshaft 6X6 350L
1993 SPORTSMAN 4X4 (W938039) - Piston & Crankshaft Sportsman 4X4
1993 TRAIL BLAZER (W937221) - Crankshaft & Piston Trail Blazer
1993 TRAIL BOSS (W938527) - Crankshaft & Piston Trail Boss
1994 300 4X4 (W948130) - Crankshaft & Piston 4X4 300
1994 400L 2X4 (W947540) - Piston & Crankshaft 2X4 400L
1994 400L 4X4 (W948140) - Piston & Crankshaft 4X4 400L
1994 NORWEGIAN 400L 6X6 (N948740) - Piston & Crankshaft 6X6 400L, Swedish S948740 & Norwegian
1994 SPORTSMAN 4X4 (W948039) - Piston & Crankshaft Sportsman 4X4 W948040
1994 TRAIL BLAZER (W947221) - Crankshaft & Piston Trail Blazer
1994 TRAIL BOSS (W948527) - Crankshaft & Piston
1994 W948040 (W948040) - Piston & Crankshaft Sportsman 4X4
1995 300 2X4 (W957530) - Crankshaft & Piston 2X4 300
1995 300 4X4 (W958130) - Crankshaft & Piston 4X4 300
1995 MAGNUM 2X4 (W957544) - Crankshaft & Piston Magnum 2X4
1995 MAGNUM 4X4 (W958144) - Crankshaft & Piston
1995 NORWEGIAN MAGNUM 4X4 (N958144) - Crankshaft & Piston W958144
1995 SWEDISH MAGNUM 4X4 (S958144) - Crankshaft & Piston W958144
1995 TRAIL BLAZER (W957221) - Crankshaft & Piston Trail Blazer
1995 TRAIL BOSS 250 (W958527) - Crankshaft & Piston Trail Boss
1996 SCRAMBLER (W967840) - Piston & Crankshaft Scrambler
1996 SPORTSMAN 4X4 (W968040) - Piston & Crankshaft Sportsman 4X4
1996 TRAIL BOSS (W968527) - Crankshaft & Piston Trail Boss
1996 XPLORER 300 (W969130) - Crankshaft & Piston Xplorer 300
1996 XPLORER 400L (W969140) - Piston & Crankshaft Xplorer 400L
1997 SCRAMBER 400L (W97BC38C) - Piston & Crankshaft Scrambler 400L
1997 SPORTSMAN 400L (W97AC38C) - Piston & Crankshaft Sportsman 400L
1997 TRAIL BOSS (W97AA25C) - Crankshaft & Piston Trail Boss
1997 XPLORER 300 (W97CC28C) - Crankshaft & Piston Xplorer 300
1998 TRAIL BLAZER (W98BA25C) - Crankshaft & Piston Trail Blazer
1998 TRAIL BOSS (W98AA25C) - Crankshaft & Piston Trail Boss
1998 XPLORER 300 (W98CC28C) - Crankshaft & Piston Xplorer 300
1998 XPRESS 300 (W98CA28C) - Crankshaft & Piston Xpress 300
1999 SCRAMBLER 400 (A99BG38CB) - Piston & Crankshaft
1999 TRAIL BLAZER 250 (A99BA25CA) - Crankshaft & Piston
1999 TRAIL BOSS (A99AA25CA) - Crankshaft & Piston
1999 XPLORER 300 (A99CC28CA) - Crankshaft & Piston
1999 XPRESS 300 (A99CA28CA) - Crankshaft & Piston
2000 TRAIL BLAZER (A00BA25CA) - Crankshaft & Piston
2000 TRAIL BOSS (A00AA32AB) - Crankshaft & Piston
2000 XPEDITION 325 (A00CK32AA) - Crankshaft & Piston
2000 XPEDITION 325 (A00CK32AB) - Crankshaft & Piston A00ck32aa
2000 XPLORER (A00AG25CA) - Crankshaft & Piston
2001 TRAIL BLAZER (A01BA25CA) - Crankshaft & Piston
2001 TRAIL BLAZER (A01BA25CB) - Crankshaft & Piston A01ba25ca
2001 TRAIL BOSS 325 SE (A01AA32AC) - Crankshaft & Piston A01aa32aa
2001 XPLORER (A01AG25CA) - Crankshaft & Piston
2002 SCRAMBLER 400 2X4 (A02BA38CA) - Crankshaft & Piston
2002 SCRAMBLER 400 4X4 (A02BG38CA) - Crankshaft & Piston
2002 TRAIL BLAZER (A02BA25CA/CD) - Crankshaft & Piston A02ba25ca/Cb/Cd
2002 TRAIL BLAZER FREEDOM (A02BA25CB) - Crankshaft & Piston A02ba25ca/Cb/Cd
2002 XPLORER 400 (A02CG38CA) - Crankshaft & Piston
2002 XPLORER 4X4 (A02CG25CA) - Crankshaft & Piston
2003 TRAIL BLAZER 250 (A03BA25CA/CB) - Crankshaft & Piston
2003 TRAIL BLAZER 400 (A03BA38CA) - Crankshaft And Piston
2004 A04BA25CA TRAIL BLAZER (A04BA25CA/CB) - Crankshaft & Piston
2005 ATP 500 4X4 (A05JD50AA) - Crankshaft & Piston /Ab/Ac
2005 MAGNUM 330 2X4 (A05CB32AA) - Crankshaft & Piston
2005 SCRAMBLER 500 4X4 (A05BG50AA) - Crankshaft & Piston /Fa
2005 SPORTSMAN 6X6 (A05CL50AA) - Crankshaft & Piston
2005 TRAIL BLAZER (A05BA25CA) - Crankshaft & Piston /Cb
2005 TRAIL BOSS 330 (A05CA32AA) - Crankshaft & Piston /Ab/Ac/Fa
2005 TRAIL BOSS 330 QUADRICYCLE (A05CA32EA) - Crankshaft & Piston
2006 TRAIL BLAZER (A06BA25CA) - Crankshaft & Piston
1 - 1 of 1 Posts
