I took the side cover off because my starter is spinning freely and I wanted to change the Bendix. When I removed it I discovered the problem was that the starter pinion gear is spinning freely on the flywheel. The starter is engaging the Bendix into the gear and it just spins around the flywheel. How is that gear supposed to be attached? I have not pulled the flywheel off to inspect yet
We need to know what ATV we are working on?? Year Make and Model??
From the sketchy description I would guess it needs a new flywheel
