2006 Hawkeye 300- 4x4 swapped, boosted, sportsman body swap
Ā·
Thanks š! Iām pretty sure this is an 06 so Iāll check those pins to the cdi and figure out what is the problem. I have done a decent amount of wiring so I probably messed something upThe 2006 Hawkeye 300 has two methods of killing the spark; Primary method, remove 12vdc from the red/wht wire of the CDI. Secondary method; connect the blk wire to ground. Assure there is 12v on the red/wht wire at the CDI unit in addition to disconnecting the blk wire.
