1 - 2 of 2 Posts
So the prop shaft seal is leaking.
Quick question... when I pull the diff forward to pull the shaft out will I need to also pull the axles?
You shouldn't have to move the differential to get he prop shaft out. Just knock the roll pin out of the front yoke slide it back off the splines and then out. You have to turn it just right to get clearance for the rear joint on the engine case. If your gonna peel out the old seal and tap in a new one you won't even have to take the shaft completely out just slide it back and off the differential.
1 - 2 of 2 Posts
