Hello,
I have replaced the bearings, seals, and pinion bushing in the front differential. I've got everything put back together but I'm having an issue with the pinion gear not freely turning. Before inserting it into the case, the bearing was very smooth. I removed the pinion gear/bearing from the case to make sure it wasn't misaligned or something and it looked fine so I reinserted it. And again it's almost impossible to turn. What is going on?
Thank you
2006 Polaris Sportsman 800 EFI
Thank you
