1 - 19 of 19 Posts
I was riding yesterday and I heard a pop. When I looked I saw that my front end differential broke off from the bracket where it mounts. This is so odd because the quad is only a year old. Has anyone had this problem and do you think polaris would cover it?
Wow, that's impressive.
Hopefully that will be covered!
looks like the bolts came lose..I dont see any on the flange part still attached...
I see three of 4 of them still on the diff; assuming that the 4th is there too and the prop shaft is just in the way from the angle.
If you have an extended warranty it would be worth going that route.
Edit: Do you have the stock plastic roller cage in the front diff still or did you upgrade it to an aluminum one?
I dont see where u see them..the diff has 3 empty holes..and on bottom the is a cracked flange on diff with no bolt in it....
edit..ok I see them now....they are torx..looking at reg view they looked empty..when zoomed i see them now....sorry
Where the red circles are, those are the bolts that hold that flange and seal in place to the diff. He's some how sheared everything off inside the the flange cause the torx-bolts are still there where they belong.
Discussion Starter · #11 ·
The bottom left bolt is still attached with a piece of the the metal. Unfortunately I bought it from a dealer who took it on a trade in. I don't think there is a warranty but I'm checking. Not exactly sure how this could happen on a year old quad. I was just going up a small hill and at the top it popped. One service guy told me $1450 for parts and $200 for service.
Discussion Starter · #12 ·
I'm pretty sure it's the stock plastic. Is this kind of break common?
Someone makes a new aluminum billet cover that is supposed to keep that from happening. Think the cover is 225.
anyone have a broken one (with all the pieces) they would be willing to send me? I wouldn't mind making a new one for mine but don't want to take it apart to get all the dimensions.
1 - 19 of 19 Posts
