My kids 2003 Sportsman 90 has a bad camber on the front end. One side worse than the other. I recently had one side with a bad toe angle and replaced a bad ball joint and didn't notice anything else loose at the time. It always had a harsh camber under braking, but would come back to a reasonable setting when riding. Now it just stays that way. Especially more on one side, but both are pretty bad. All I find on initial check is some wobble by hand in the wheel bearings, about 1/4 inch at it's worst if I was to actually measure the back and forth movement at the tread surface center of tire. Not sure how much play should be there. I think replacement of bearings is needed, but it seems irrelevant to the sag issue. Shocks? They have always been set to the softest setting to prevent bouncing as he is pretty light. Spindles/knuckles? Could they be bent or worn that bad? Anyone know or have experienced the tendencies of these machines? I don't want this to be a parts replacing deal till it is fixed if I can help it. Also does any one know where to get a rear sprocket with out having to buy the hub, bolts and washers along with the sprocket? Thanks in advance for any input.
