1 - 20 of 35 Posts
The last two rides my 1000XP has developed a shake in the front end, starts at around 49 MPH and get worse the faster I go. I am going to pull the wheels and start with a visual inspection of the components I can see. I hope I can see something obvious.
Anyone have a suggestion as to what to check first if I don't see anything?
Before you pull tires ,,,rod ends, ball joints and wheel bearings wear fast. I had 800 miles when I needed to replace ball joints and 1 rod-end on each side.I just replace everything with aftermarket.And since I was in there I switched to GP bushing's
Jack up front end
Put both hands on each wheel in the 9 and 3 o’clock positions. Gently push the wheel to the front and back simulating turning the steering. You’ll be looking for looseness in the steering. If one wheel moves slightly before the other, you could have worn steering tie rod ends.
Placing your hand at the 12 o’clock position on the wheel while then pushing in at the top will reveal loose wheel bearings. If there is any movement to the slightest pressure from the 12 o’clock position, you might have a wheel bearing issue.
The last test is for the ball joints that hold the upper and lower control arms to the wheel hub or steering knuckle. Pulling out, then pushing in on the bottom of the wheel while observing the Upper and lower A-Arms will reveal loose ball joints.
Do you have stock tires? It's always a good idea to check suspension/steering components regularly but out of balance/out of round tires are usually the culprit for high speed shakes in my experience.
My brand new 1k with no miles would shake its head like a mad bull from 45 on up. Replaced the OEM tires with good ones and now its smooth as silk at all speeds.
I've got a new set of PXT's for sale cheap if anyone is interested. They will have to be balanced though.
Discussion Starter #4 (Edited)
I'm running a set of Interco Sniper 920s 8 plys. Had them balanced BUT I ride hard and take a lot of rock hits at speed so they may need rebalanced. I'm going out to the shop to take a look at the machine. I will report back with what I find.
Polman, what tires are you running?
Mike
Just finished up doing my inspection, looking at what Duse suggested. Sure enough the inner tie rod ends have about a 1/8th inch of slop on EACH. I am surprised they didn't just fall off. The rest checked good. Unreal for a machine I bought new in May.:sad Still going to rebalance the tires.
Mike
I am in the last month of the warranty. Dealer just told me the tie rods are not covered. Normal wear and tear he said.
Anyone know of a better than stock tie rod end?
Mike
EDITED TO ADD
Just found an upgrade kit from a company here in Utah. Here is a link to the parts I ordered in case anyone else is interested.
https://www.ebay.com/itm/352138047139
Discussion Starter #8
Dug a little deeper this morning, pulled the wheels off to get them rebalanced and found the lower A arm bushings are shot. I know I ride hard but hell I only have 1600 miles on the machine. I lubed them every other ride and the machine has never seen any mud. We have been in drought with no rain for months. Getting kind of pissed, you would think a $12,000 plus machine would hold up better.
The OEM bushings are junk. This is the reason companies are making more durable ones than stockers. One of them even gives you lifetime warranty on the their replacements
Discussion Starter #10 (Edited)
Mike
EDITED TO ADD
Got them installed, they are a lot more beefy than stock. Time will tell how they hold up.
Were the others just loose or did they really need full replacement? I'd be totally shocked if those few miles would necessitate tie rods already. Hell, my 2001 Honda Rancher with ~8500 miles has factory suspension still intact.
Discussion Starter #12
The tie rods themselves weren't bad, just the inner ends were loose. The outer ends were fine. The OEM rods are 11mm. The new rods are 12mm for the heavier tie rod ends. As far as the A arm bushings, it was the lower arms mainly on right side. I ordered a complete set of new delron bushings, however they won't get installed till a later date. I went ahead and replace the worn ones with OEMs to get it back ridable sooner. The new OEMs were tighter but still have a little play. I am changing to a little heavier grease in the future.
Mike
EDITED TO ADD
Any feedback on how this kit has held up?
Discussion Starter #14
Well, it's kind of coincidental I was doing maintenance on the machine last night. The inner joints were loose. I have just over 4k on the odo now. So I have to say the new rod ends are no better than the OEMs. Don't know what brand to try next:sad
Well that’s unfortunate. Sorry to hear it. Super ATV has ball joints but I’m not sure on tie rods. Maybe worth a call?
Discussion Starter #16
I called American Star racing today and discussed the wear issue with the tie rods I purchase in Oct. They said depending on riding condition the tie rod end could wear out faster than normal. Kind of a generic answer, but I agree. I do ride very aggressively and in very rocky conditions most the time.
That said, the American Star folk are sending a new set of their racing tie rods to try. GREAT customer service!!! Below is a link to what they are sending.
https://www.ebay.com/itm/American-Star-4130-PRO-MOLY-Tie-Rod-Kit-2018-Polaris-Sportsman-1000-XP/352635013929?_trkparms=aid=111001&algo=REC.SEED&ao=1&asc=20160908105057&meid=0451a6e7bece4d50b005fb50d3c88a27&pid=100675&rk=1&rkt=15&sd=352635013929&itm=352635013929&_trksid=p2481888.c100675.m4236&_trkparms=pageci:1cc3a25d-8184-11e9-a358-74dbd180d571|parentrq:000d57d416b0aaa321c123fbffd9a024|iid:1
Damn, good to know! Too bad I just ordered the set you had prior!
Discussion Starter #18
I truly think as long as I ride like I do and where I do, I will be replacing the tie rod ends, a-arm bushings and wheel bearings every six months or so. The price of having fun.:sad:
That makes 2 of us. Oh well I don’t intend to change that! Keep us updated on how the new set holds up.
1 - 20 of 35 Posts
