1 - 8 of 8 Posts
Nooby here: I was wondering if anyone knows if part # 4170003 front hub coil and 2201313 front hub coil kit are the same except for the electrical connectors? 4170003 is online for roughly 30$ and 2201313 is 95$. I am thinking that they are the same specs. except for how they plug up electrically. For 65$ I can solder wires together and have same results. Thanks for any insights!
It is a 2001 magnum 325 awd....the coils seem to be the same. the 4170003 part # ends at 1999 models but the 2201313 kit supercedes after 1999. I am thinking if 2201313 fits 1999 and older then the old part # should fit newer models also.
Hmm, it might work. I don't know where you're looking but Polaris microfiche shows 4170003 ending in 1994 with several different substitution numbers until 2201313 substitutes starting in 1997. It's hard to say for sure if there's any difference other than the connectors. Someone else may chime in that knows for sure or you might call the vendor to see if they would measure it for you.
Let us know what you find out.
Discussion Starter #8
Thanks for the insight...I think I will order one of the 30$ parts to verify it works and if it does I will order the other.
This magnum has no speedo so how does the awd system "ground"? I know on my sportsman the awd sytem grounds thru. the speedo. but what about a bike with no speedo. (from the factory that way)?
Thanks again for your help!
1 - 8 of 8 Posts
