Hey guys I am new to the scrambler and 4x4 in general. I need to change the oil in the front hubs. Without going to Polaris, what type of oil goes in those hubs? Thought I read on here somewhere that I should use Type F trans fluid, let me know, thanks
IMO as much as you may not want to use polaris oil here, you really should. 1qt will change you 2-3 times easily, and its a yearly thing. your risking proper operation of your 4x4 system without the OEM fluid, its special, polaris wont say how special, but it seems to cause problems more often then not if you run anything else
type F is fine
^^yeah i havent been able to confirm it is the same, which is why i always recommend the OEM stuff here.....but if it has a decent track record then of being okay.....
One Qt will last you a long time!
