1 - 15 of 15 Posts
Does the front lock & ride box attach to the existing rack or is it a separate assembly that just mounts?
I have front rack extenders and see that is says "DOES NOT FIT with Front Rack Extenders"
On my 2014 850xp it is a completely seperate unit from the stock rack.
Cool! Thanks for info!!! I still wanted to be able to use my existing rack at times for general work but wanted box for rides out on the trail.
If it is like a 2010 the cargo box replaces your original rack assembly. It does not fit onto your original rack. Unless things have changed.
Thanks guys! This helps the confidence level about ordering something and knowing it will definitely fit without issues.
I will have to look around some but has anyone every put rack extender on front lock & ride box? Not sure if it is even possible.
I realize it might block high beam but that isn't an issue for me.
Only take you a few min to swap out the two. The box is a lock and ride add on. Takes about 10 seconds to remove. Then just put your rack with extender back on.
Good point! I'm gonna pick one up.
Thanks!
Discussion Starter #10
Just ordered from Amazon since I had a $30.00 gift card and free shipping so $139.
With a little tweaking you can mount the rack extender on the lock and ride cargo box, but it won't fit on the rack after its customized! :)
Sent from my SAMSUNG-SGH-I747 using Tapatalk
That's a good deal!
Babbits online has them for $144.49 but then you have to pay shipping, so was yours $139.00 with free shipping and then you get to use your gift card? or was it $169 and you got the $30 off that?
Discussion Starter #14
I've decided to leave the extender off of it.
Discussion Starter #15
It was $169 and using my $30 Amazon gift card it was $139/shipped.
1 - 15 of 15 Posts
