I can't find it on my 2012 Touring 850.
2 2Tanks · Registered Joined Oct 2, 2012 · 249 Posts Discussion Starter • #1 • Oct 31, 2013 I can't find it on my 2012 Touring 850.
R Russ C · Registered Joined Feb 13, 2011 · 4,243 Posts #2 • Nov 1, 2013 Look up thru hole in right floorboard
2 2Tanks · Registered Joined Oct 2, 2012 · 249 Posts Discussion Starter • #3 • Nov 1, 2013 I have. Is it further back like towards the middle of the atv? Call me if you can. Thanks Mark 918-704-5538
2 2Tanks · Registered Joined Oct 2, 2012 · 249 Posts Discussion Starter • #4 • Nov 3, 2013 Found it. Can I use the marine grease in my gun for it or do I have to use Polaris specific u joint grease?
5254 · Registered Joined Jun 3, 2010 · 6,824 Posts #5 • Nov 3, 2013 2Tanks said: Found it. Can I use the marine grease in my gun for it or do I have to use Polaris specific u joint grease? Click to expand... I ise a synthetic grease onlu. Gets used on the tractor, truck, ATV, and anything else that needs it.
2 2Tanks · Registered Joined Oct 2, 2012 · 249 Posts Discussion Starter • #6 • Nov 3, 2013 So synthetic grease on the yoak zurk fitting and marine grease on the rest cause I take it mudding?
5254 · Registered Joined Jun 3, 2010 · 6,824 Posts #7 • Nov 3, 2013 Marine grease should be stnthetic. Use marine on the entire bike. It wont hurt anything.
2 2Tanks · Registered Joined Oct 2, 2012 · 249 Posts Discussion Starter • #8 • Nov 3, 2013 Thanks Will
