Hey guys, I just bought an 05 sportsman 500 and it has mud lites. I was just wondering, the front tires lean in towards each other at the top ever so slightly, is this a problem? What is it called?
Its called negative camber and my 2010 sportsman 500 has it also. Its normal and non adjustable according to my service manual..........BG
It's normal. If you want to fix it you can put in new springs. There's several threads about it. You can use Polaris HD springs (128lbs/inch), EPI HD springs (120lbs/inch), MV7 springs (170lbs/inch), or even ranger (not sure about their compression rates) springs if you want to go REALLY stiff.
